Grid Mosaic from Grid File(s)
Use the Grid and Image > Utilities > Grid Mosaic from Grid File(s) menu option (MOSAIC GX) to create a single grid from a mosaic of input grids.
Grid Mosaic from Grid File(s) dialog options
A mosaic is created by creating a new grid large enough to hold all the component grids in the projection and resolution of the first grid. Each grid will be reprojected and resampled as required and placed in the output grid. Only non-dummy values from each grid are used, and later grid values will replace earlier grid values if the grids overlap.
