CBAR (Draw a colour scale bar)
This command will draw a colour scale bar and create a plot file that can be used in CPLOT to fill in the colour on the scale bar.
Command Syntax:
zone,zlog,zmlt,zoff,zfmt,att,height,width,space,slant,font
text,off,att,height,width,space,slant,font
Command Parameters:
refp |
Reference point (0 - 11) from which to refer the following offsets. The default is reference point 6. |
x,y |
Location of the bottom of the colour bar relative to the reference point. The default is -6,0 cm. This places the colour scale bar in the top half of the map, 6 cm from the right edge. |
dx,dy |
The size of the colour box in map units. Default is 1,0.6 cm. |
att |
Attribute used to draw box edges. |
Sub-Command Parameters Line 1:
Sub-Command Parameters Line 2: (this line can be repeated)
Example
Z1
"Total Field"
"(nT)"
This will draw a colour scale bar 4 map units left of the center of the right edge of the map. A grid file name CBAR.GRD will also be created in the local directory. This grid can be used with CPLOT to fill the scale bar with colour.
