New Map from X,Y
Use the New Map dialog to finalize creating a new blank map based on the X,Y data range specified.
New Map dialog options
Map name |
Specify the name of the new map. |
Select a standard template to be used to define the map layout. The map layout includes the media size, map margins and basic map drawing style. The [Templates] button will enable you to modify existing templates and add your own new templates. |
Specify the desired map scale. If left blank, a default scale will be calculated to fit the data range to the specified template. The [Scale] button will calculate and display the default scale, which can be modified to an appropriate scale, if desired. |
Coordinate System |
Displays the current coordinate system. |
Distance unit |
Displays the current distance unit. |
[Templates] |
Click the button to open the MAPPLOT Template Manager dialog to modify an existing template or create a new template. |
An empty new map will be opened in your workspace.
