Sensor Data Noise
Use the Sensor Data Noise option (geogxnet.dll(Geosoft.GX.AirborneQC.SensorDataNoise;Run)*) from the Airborne QC menu to identify noise in the data by calculating the fourth differences between values in a channel.
Sensor Data Noise dialog options
This GX assumes that the current database is the one containing the actual survey data. The database is called the survey database. If you wish to process a different database, you may browse to add it to the project or select one from the workspace list.
Quality Control Specifications and Indicators
This GX creates a channel called Flag_Noise. Fourth differences are calculated for the input channel. The difference values outside the range defined by +/- the specified tolerance will have the value of 1 placed in the Flag_Noise channel (differences with a dummy result in a dummy). The sign of the flag is the sign of the 4th difference. Values within the tolerance range will be flagged with a 0.
Indicator Definition
0 |
Noise level is acceptable. |
±1 |
Noise level exceeds the specified limit. |
