Display the Survey Plan
Use the Display the Survey Plan option (QCPLAMAP GX)) from the Airborne QC > Generate Flight Path Plan menu to display the survey plan generated by Create a Survey Plan either in the current map or a new map.
Display the Survey Plan dialog options
This GX plots the boundary of the survey, the survey lines and the tie lines listed in the current database. The colour and thickness for each category can be set independently. By default, these are plotted on the current map. If the ‘Create a new map’ option is selected, a second dialog box appears requesting the map name. It also enables you to set the map layout and style.
