Save Database As
Use the Database > Save As menu option (SAVEGDB GX) to save the current database to a new file.
Save Database As dialog options
New database file |
The name of the new database file. Script Parameter: SAVEGDB.NAME |
Compression type |
The type of compression to use with the new database:
For a description of each compression type, click here. Script Parameter: SAVEGDB.COMPRESSION |
The current database will be saved to a new file; all changes will be committed to the new file. The original database will be closed after discarding any changes.
