Scan Picodas Data
Use the Database > Import > Picodas PDAS > Scan Data menu option (SCANPICO GX) to scan a given Picodas file and create a default import template. The template can be edited and modified to remove unwanted channels and to re-name lines as required using the ALIAS keyword.
Scan Picodas Data dialog options
Picodas Data file to scan |
Picodas data file name. Script Parameter: SCANPICO.DATA |
Create Picodas Template file |
Template file name (.I1 assumed). Script Parameter: SCANPICO.TEMPLATE |
