Set Default Drawing Plane
Run SETDVIEW GX to set the current drawing plane, on an open map, as the "default" drawing plane.
All drawing of spatial data on a map, such as location plots or contours, is placed in the current default drawing view. If a map has more than one data view, you can use this GX to set the default drawing view before running a GX that draws data.
