General Settings
Use the Project > Settings > General menu option (SETTINGS GX) to change the "general" default settings for your Oasis montaj environment. These are global variables and remain set for a given installation of Oasis montaj. The values are stored inside the 'geosettings' file located in the user specific folder '%USERPROFILE%\Documents\Geosoft\Desktop Applications \ini'. This means they remain the same for different data sets and Oasis montaj projects.
General Settings dialog options
Default project directory |
The default location for your projects is set under your user profile Documents folder: %USERPROFILE%\Documents\Geosoft Projects. The subdirectory "Geosoft Projects" will be created if it does not exist. Use the browse [...] button to select a different location for your project directory. New projects will be created under the selected parent folder. |
Select the menu files (*.omn) to load as the default menus when creating a new project. If more than one menu is selected, each menu must be separated by the | character. Example: coremenus.omn|magmap.omn
Script Parameter: SETTINGS.DEFAULT_MENU |
Select the default colour scheme for rendering the image of grids. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: SETTINGS.DEFAULT_COLOUR |
Select the default colour scheme for rendering the image of symbols. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: SETTINGS.DEFAULT_MAP_FONT |
Default colour method |
Set a preferred default colour distribution method for your project. Select the default colour method for rendering colour distributions as one of the following options: Equal Area, Linear, Log-Linear, or Normal. All your displayed grids in your project will now use this colour distribution method.
Script Parameter: SETTINGS.DEFAULT_COLOUR_METHOD |
Default distance unit |
Select the default ground distance unit (e.g., metre, kilometre, centimetre, foot, etc.) Script Parameter: SETTINGS.DEFAULT_UNIT |
Default map font |
Select the default map font. The configuration settings file 'truetype.ini' will be modified to map the "default" font from Geosoft PLT files to the TRUETYPE font specified here. To change the mappings of other fonts you can modify the 'truetype.ini' file directly.
Script Parameter: SETTINGS.DEFAULT_SYMBOL_FONT |
Default symbol font |
Select the default symbol font (*.gfn) for selecting plot symbols. Script Parameter: SETTINGS.DEFAULT_SYMBOL_FONT |
Specify the default type of compression to use when creating a new database. There are three options:
Script Parameter: SETTINGS.COMPRESSION |
Select the text file editor program to use to view and modify text files. You can also set the editor through the Select a Default Text Editor dialog.
[Next] |
Click Next to continue with more settings. |
More Settings dialog options
Select the input grid format you would like to use by default. Script Parameter: SETTINGS.DEFAULT_XGD_IN |
Select the output grid format you would like to use by default. Script Parameter: SETTINGS.DEFAULT_XGD_OUT |
Specify the default option to use when creating a Geosoft grid. There are three options:
Script Parameter: SETTINGS.XGD_DEFAULT |
Load last project? |
When you start Oasis montaj, you are prompted to select a project to open. Change this option to Yes, and the last project you were working with will open automatically. |
Confirm database saves? |
If the option Yes is preserved, when you close a project, you will be asked if you want to save any open databases. If you select No, the database(s) will be saved automatically. Script Parameter: SETTINGS.CONFIRM_GDB_SAVE |
Specify coordinate system on import? |
Select if you would like to be prompted for coordinate system information on import. If Yes is selected, when importing to a database and there is no projection specified in the current X and Y channels, then the SETCHPRJ GX is run so that you can set up the projection. Some imports do their own specification of projection and are not affected by this setting.
Script Parameter: SETTINGS. NEW_GDB_PROJECTION |
Error report level |
Select the message level you want to see. If All errors is selected, you will see more error messages each time an error occurs. This is useful when contacting Script Parameter: SETTINGS.ERROR_LEVEL |
Oasis montaj provides the ability to nest your saved print files (*.PRN) for HP-RTL printing. Set the HP-RTL nesting option to "on" to enable the plotting of multiple maps on a single map sheet. When you enable or disable nesting on an HP-RTL printer: the "INIT" parameter in the [HPRTL] section is set to the "INIT_NEST" or "INIT_NONEST" value respectively.
Script Parameter: SETTINGS.HPRTL_NESTING (0: off (default), 1: on) |
Temporary file directory |
This directory is used by Oasis montaj to store temporary files. Depending on the application, the requirements for storage in this directory can be very large (from 10 megabytes to gigabytes). We recommend setting this parameter to a very fast drive. This will improve performance of all large data operations (e.g., MAGMAP filtering, gridding, etc.) Oasis montaj cannot start if this drive is invalid or if it is set to a drive in which it cannot create files. Please ensure that the directory is always valid.
In previous versions of Oasis montaj, the GEOTEMP environment variable determined where this directory was stored. This variable is no longer used and the setting is controlled through the Windows registry.
