Sort All by Multiple Channels
Use the Database Tools > Channel Tools > Sort All by Multiple Channels menu option (SORTALLN GX) to sort all channels based on two reference channels. The data is first sorted by a primary reference channel, then for data with the same value in the primary reference channel, the data is sorted by the secondary channel.
Sort All by Multiple Channels dialog options
Primary channel |
Primary channel on which to base the sort. The data will first be sorted by this channel, then by the secondary channel. Script Parameter: SORTALLN.CHANNEL1 |
Primary sort |
Ascending or Descending. Script Parameter: SORTALLN.ORDER1 |
Secondary channel |
Secondary channel on which to base the sort. For data in which the primary channel is the same, the data will be sorted by the secondary channel. Script Parameter: SORTALLN.CHANNEL2 |
Secondary sort |
Ascending or Descending. Script Parameter: SORTALLN.ORDER2 |
Tertiary channel |
Secondary channel on which to base the sort. For data in which the primary channel is the same, the data will be sorted by the secondary channel. Script Parameter: SORTALLN.CHANNEL3 |
Tertiary sort |
Ascending or Descending. Script Parameter: SORTALLN.ORDER3 |
Quaternary channel |
Fourth channel on which to base the sort. For data in which the primary channel is the same, the data will be sorted by the secondary channel. Script Parameter: SORTALLN.CHANNEL4 |
Quaternary sort |
Ascending or Descending. Script Parameter: SORTALLN.ORDER4 |
Sort read-only channels? |
Yes to sort read-only channels, No to not sort read-only channels. Script Parameter: SORTALLN.READONLY |
If a channel is not sampled at the same rate as the reference channels, the reference channels are re-sampled to match the channel being sorted.
All defined channels are used in the sort; e.g. if the third channel is left blank, then the first, second and fourth are used to create the sort index.
If protected channels are not sorted, the fiducial relationships will be lost, and data integrity may be lost.
