Fill Voxel Dummies
Use the Voxel > Utilities > Fill Voxel Dummies menu option (geogxnet.dll(Geosoft.GX.VoxUtils.FillVoxel;Run)*), to fill the dummies in an existing voxel and write the filled volume to a new voxel.
Fill Voxel Dummies dialog options
Input voxel |
Select the voxel file to be filled. Script Parameter: FILLVOXDUMMIES.INPUTVOXEL |
Output filled voxel |
Select the name for the filled voxel file. Script Parameter: FILLVOXDUMMIES.OUTPUTVOXEL |
Fill type |
Select the interpolation type:
