Velocity Channel to Density Conversion
Use the option Database Tools > Database Utilities > Convert Velocity to Density, (geogxnet.dll(Geosoft.GX.VelocityToDensity.VelocityToDensity;Run)*), to convert a database channel containing seismic (P-wave) velocities into rock densities using one of the several published methods. The option is also available in the GM-SYS Profile Modelling extension.
Convert Velocity Channel to Density dialog options
Input velocity channel |
Select the name of the existing channel containing velocity values to be converted. Script Parameter: VEL2DEN.CHANNELINPUT |
Velocity units |
Select the density units that the values in the output channel represent. Script Parameter: VEL2DEN.UNITSINPUT |
Output density channel |
Select the name of the new or existing channel that will contain the calculated density values. Script Parameter: VEL2DEN.CHANNELOUTPUT |
Density units |
Select the name of the new or existing channel that will contain the calculated density values. Script Parameter: VEL2DEN.UNITSOUTPUT |
Method |
Select the conversion method from the list. The valid range of velocities for each method is shown. Script Parameter: VEL2DEN.METHOD |
Dummy outside range |
Each conversion method is defined within a range of velocities (and corresponding densities). Check this box if you wish to dummy calculated values that fall outside of the defined range. Script Parameter: VEL2DEN.DUMMY |
Published empirical relationships between seismic velocity and bulk density of various rock types are commonly used in processing seismic data (Gardner et al., 1974; Brocher, 2005). The Convert Velocity Channel to Density GX and Convert Density Channel to Velocity GX utilize 5th order polynomial expansions to approximate several of these relationships to less than 0.001 g/cm3 variance. Velocity to Density function and the inverse Density to Velocity function should match to within 4 significant figures.
Additional Methods
We have implemented Gardner, Nafe-Drake, and some other conversions as 5th order polynomial functions. The method names, coefficients, and appropriate velocity ranges are stored in the vel_density.csv file in the Oasis montaj distribution. Coeffients for Nafe-Drake, Christensen & Mooney, and Godfrey et al. methods are adapted from Brocher (2005). "Gardner" methods use coeffients derived from the tables in Gardner et al., 1974.
Additional Velocity-to-Density conversion functions may be added by editing the %USERPROFILE%\Documents\Geosoft\Desktop Applications \csv\vel_density.csv file. The conversion must be represented by a 5th order or lower polynomial, as described in the file header. Coefficients are appropriate for Velocity units of m/s and Density units of g/cm³ and unit conversions are performed by the GXs.
References
- [1] Gardner, G.H.F., Gardner, L.W., and A.R. Gregory, 1974, "Formation velocity and density - The diagnostic basics for stratigraphic traps", Geophysics, vol. 39, no. 6, pp. 770-780.
- [2] Brocher, T.M., 2005, "Empirical relations between elastic wave speeds and density in the Earth's crust", Bulletin of the Seismological Society of America, vol 95, no. 6, pp. 2081-2092.
