Window Array Channel
Use the Database Tools > Array Channels > Window menu option (VAWINDOW GX) to extract the sum or average of values from a window of an array channel to a new channel.
Window dialog options
Array channel to window |
The array channel to window Script Parameter: VAWINDOW.VA |
Output channel |
The name of an existing or new output channel Script Parameter: VAWINDOW.VV |
Start element (0 is first) |
The first element in the window (starting from element 0) Script Parameter: VAWINDOW.START |
Number of elements |
The number of elements in the window Script Parameter: VAWINDOW.LENGTH |
Sum or average |
Choose to sum or average the elements. Script Parameter: VAWINDOW.MODE=Sum or Average |
This dialog option is used to extract windows of information from array channels. For example, this dialog can be used to extract radiometric windows from 256 channel radiometric windows.
The output window is the simple sum or average of values in the array window. If any array values are dummy, the result will be dummy.
If the output channel does not exist, it will be created using the data type of the input array channel.
