Apply View Mask
Use the Map Tools > Masking > Apply View Mask menu option (VIEWCLIP GX) to reset the clip area of a view to a polygon mask file.
Apply View Mask dialog options
After changing a view clip area, groups within the view can be clipped to the view clip limits by setting their clip attributes. To do this, select the group to be clipped, press the right mouse button, and select the "clipped" option in the pop-up menu.
Polygons are ASCII files with default extension .ply. A polygon file contains a list of X,Y coordinates that define one or more polygons. The file may contain any number of polygons, and each polygon may have any number of vertices. The first and last points in each polygon are assumed to connect. If the file will contain more than one polygon, each polygon must start with a line 'poly #' ('p' or 'P' in column 1). Comment lines are indicated by a '/' in column 1.
Clip polygon files may also be generated interactively by using the digitising tools in the Map Tools menu.
Example of a single polygon file:
/ Sample single polygon file
poly 1
1376027.6061 6178025.9399
1382846.3129 6178025.9399
1382846.3129 6182748.8182
1376027.6061 6182748.8182
Example of a three polygon file:
(Note the exclusive following the poly 3 entry; this indicates exclusive regions or holes in polygon sets.)
/ Sample three polygon file
poly 1
1375594.6724 6181961.6718
1378706.3838 6181961.6718
1378706.3838 6184716.6842
1375594.6724 6184716.6842
poly 2
1375757.0225 6178629.4188
1379896.9516 6178629.4188
1379896.9516 6181174.5254
1375757.0225 6181174.5254
poly 3
exclusive
1380546.3523 6175926.8828
1384550.9896 6175926.8828
1384550.9896 6179022.992
1380546.3523 6179022.992
