Velocity Voxel to Density Conversion
Use the option Voxel > Utilities > Convert Velocity to Density, (geogxnet.dll(Geosoft.GX.VelocityDensityConversion.VelocityVoxelToDensity;Run)*), to convert a voxel containing seismic (P-wave) velocities into rock densities using one of several published methods. The option is also available in the GM-SYS 3D Modelling extension.
Convert Velocity Voxel to Density dialog options
Input velocity voxel |
Select an existing voxel containing velocity values to be converted. Script Parameter: VOXVEL2DEN.INPUT_VOXEL |
Velocity units |
Select the velocity units that the values in the input voxel represent. Script Parameter: VOXVEL2DEN.VELOCITY_UNITS |
Output density voxel |
Select the name of the new or existing voxel that will contain the calculated density values. Script Parameter: VOXVEL2DEN.OUTPUT_VOXEL |
Density units |
Select the density units that the values in the output voxel represent. Script Parameter: VOXVEL2DEN.DENSITY_UNITS |
Method |
Select the conversion method from the list. The valid range of velocities for each method is shown. Script Parameter: VOXVEL2DEN.METHOD |
Dummy outside range |
Each conversion method is defined within a range of velocities (and corresponding densities). Check this box if you wish to dummy calculated values that fall outside of the defined range. Script Parameter: VOXVEL2DEN.USE_DUMMIES |
Published empirical relationships between seismic velocity and bulk density of various rock types are commonly used in processing seismic data (Gardner et al., 1974; Brocher, 2005). The Velocity to Density and Density to Velocity conversions utilize 5th order polynomial expansions to approximate several of these relationships to less than 0.001 g/cm3 variance. Velocity to Density function and the inverse Density to Velocity function should match to within 4 significant figures.
Addtional Custom Methods
Additional Velocity-to-Density conversion functions may be added by editing the %USERPROFILE%\Documents\Geosoft\Desktop Applications \csv\vel_density.csv file. The conversion must be represented by a 5th order or lower polynomial, as described in the file header. Coefficients are appropriate for Velocity units of m/s and Density units of g/cm³ and unit conversions are performed by the GXs.
References
- [1] Gardner, G.H.F., Gardner, L.W., and A.R. Gregory, 1974, "Formation velocity and density - the diagnostic basics for stratigraphic traps", Geophysics, vol. 39, no. 6, pp. 770-780.
- [2] Brocher, T.M., 2005, "Empirical relations between elastic wave speeds and density", Earth's crust Bulletin of the Seismological Society of America, vol 95, no. 6, pp. 2081-2092.
