Warp Data
Use the Coordinates > Georeferencing > Warp Data menu option (WARPDATA GX) to create a pair of new coordinate channels from an existing pair of coordinate channels.
Warp Data dialog options
Current X/longitude channel |
Select the current X/longitude channel. Script Parameter: WARDATA.OLDX |
Y/latitude channel |
Select the current Y/latitude channel. Script Parameter: WARPDATA.OLDY |
Warp definition file (.wrp) |
The name of the Warp definition file (*.wrp). Script Parameter: WARPDATA.WRP |
Output X/longitude channel |
Select the output X/longitude channel. Script Parameter: WARPDATA.NEWX |
Select the output Y/latitude channel. Script Parameter: WARPDATA.NEWY |
This GX enables you to apply a warp to existing X and Y channels and output the results to a second set of channels with names you specify. You can then apply other operations such as gridding to the newly warped data.
