Run Process
Use the Project > Scripting > Run Process menu option (WINEXEC GX) to open a command console and run a process.
Run Process dialog options
Command name |
command Script Parameter: WINEXEC.COMMAND |
Command line arguments |
command line arguments Script Parameter: WINEXEC.ARGS |
Command type |
"E" for EXE or COM "D" for BAT or system commands or "W" for Windows EXE Script Parameter: WINEXEC.TYPE |
Action when complete |
"H" to hold screen when done, "E" to hold screen on error, "D" don't hold the screen Script Parameter: WINEXEC.EXIT |
This GX will only run under Oasis montaj for Windows. The hold screen ("H") and hold screen on error ("E") options are equivalent in the case of the Windows EXE command type ("W"). The Windows EXE option allows running a process and continuing execution of montaj or script without waiting for the process to finish if the don’t hold screen option ("D") is used for the action when complete.
