Import UBC DCINV2D/IPINV2D Files
Use the Map > Import > UBC DCINV2D/IPINV2D Files menu option (geogxnet.dll(Geosoft.GX.IP.ImportUBC2D;Run)*), to
convert UBC DCIP2D conductivity and chargeability files to Geosoft Grid files
and display them to a map.
Use the Add to 3D > Imports > UBC DCINV2D/IPINV2D Files menu option (geogxnet.dll(Geosoft.GX.IP.ImportUBC2D;Run)*), to
and display them to a 3D View.
Import UBC DCINV2D/IPINV2D Files dialog options
Mesh File
Select the model mesh file. This file provides the model
specification for the conductivity/chargeability data contained within the model
files specified below.
Script Parameter: IP_IMPORTUBC2D.MESH
Topography file
Select the topography file. The "top elevation" value from the
topography file gives the true elevation at the top of the mesh; the depths
contained in the mesh file are given relative to the top of the mesh.
Script Parameter: IP_IMPORTUBC2D.TOPO
Conductivity file
Select the conductivity model file to convert to a grid. Either the
conductivity model file or the chargeability model file must be selected. The
conductivity model file must be specified in order to produce a resistivity
grid.
Script Parameter: IP_IMPORTUBC2D.CON
Create resistivity grid also
The conductivity model file must be specified in order to create an
accompanying resistivity grid. The resistivity is calculated by taking the
reciprocal of the conductivity values.
Script Parameter: IP_IMPORTUBC2D.RES: (0:No, 1:Yes, Default 0)
Chargeability file
Select the chargeability model file to convert to a grid.
Script Parameter: IP_IMPORTUBC2D.CHG
Prefix for output filenames
Select a string of text to put at the start of the output grid filenames.
Underscores are not automatically included, so if you wish to separate the
prefix and the rest of the filename with an underscore, be sure to include it in
the prefix text.
Script Parameter: IP_IMPORTUBC2D.PREFIX
[More] - click this button to display additional parameters
Output grid cell size (X)
Output grid cell size (Z)
By default, the output grid cell size is determined by examining
the model mesh and selecting the most-repeated value. Normally, in a given row,
the padding cells surround, and are larger than, the interior model cells. If a
cell size different than the original model cell size is selected, values are
interpolated. For the "Z" cell size, the top-most cell size is used as the
default value.
Script Parameter: IP_IMPORTUBC2D.CELLX, IP_IMPORTUBC2D.CELLZ
Padding cells to trim on left side
Padding cells to trim on right side
Padding cells to trim at bottom
Select the number of cells to trim from the left side of the mesh
model. By default, all cells up to the central "block" of cells are trimmed.
Script Parameter: IP_IMPORTUBC2D.TRIM_LEFT,
IP_IMPORTUBC2D.TRIM_RIGHT, IP_IMPORTUBC2D.TRIM_BOTTOM
[Calculate from Mesh File]
Click this button to calculate the cell size and padding cell values from the
currently selected mesh file.
Setting the DUMMY
All values in the input Conductivity file less than 10-8 x maximum conductivity are dummied on input. For example, if the maximum conductivity value in the input conductivity file is 0.1, then all values below 10-9 will be set to dummy. Since conductivities are always positive values, you can represent the dummy value in the input conductivity file with a very small positive value such as 10-32 and skip checking the maximum value in the input conductivity file.
Output Filenames
The output grid filenames are composed of the input grid file names, with the
optional prefix, and "CON", "RES" or "CHG" as a suffix. For instance, if the
optional prefix is defined to be "L100_", then you will get the following grid
filenames:
dcinv2d.con -> L100_dcinv2dCON.grd (Conductivity grid)
dcinv2d.con -> L100_dcinv2dRES.grd (Resistivity grid)
ipinv2d.chg -> L100_ipinv2dCHG.grd (Chargeability grid)
Additional XYZ Files
In addition to the grid files, the import produces Geosoft XYZ files containing
the original model data used to construct the grids. The files consist of three
columns of space-delimited values. The first two columns give the original UBC
(X, Z) model location, while the third value is the model resistivity,
conductivity or chargeability. The list of values is the trimmed model, and has
all dummy values removed.
