Inline IP Stacked Section in 3D View
Use the Inline IP Stacked Section in 3D View menu option (IP3DVIEW GX) to create a new 3D View on a map from existing pseudo-sections plotted on an IP map.
Inline IP Stacked Section in 3D View dialog options.
New 3D View name |
Enter the name for the new 3D View. Script Parameter: IP3DVIEW.VIEW |
This dialog was designed principally for the stacked section maps, to show the individual sections as they are oriented in real (3D) space. It will also work on the single-line pseudo-section maps, but because each of the sections in those maps are at the same location, only one is plotted.
A new 3D View will be placed in the centre of the currently displayed map window. You may move and scale the 3D View just as you would any other view on the map.
