Export to Interpex I2X Format File
Use the IP & Resistivity > Export > Interpex I2X Format option (IPEXPRESIX GX) to export lines from the current database to Interpex I2X format files.
Export to Interpex I2X Format dialog options
Resistivity (Data) channel |
Resistivity Data Channel for export. Select one from the list. This field is required. Script Parameter: IP.I2X_RES_DATA |
IP (Data) channel |
IP Data Channel for export. Select one from the list, or leave blank and none will be exported. Script Parameter: IP.I2X_IP_DATA |
Image model resistivity channel |
Apparent resistivity from image model channel for export. Select one from the list, or leave blank and none will be exported. Script Parameter: IP.I2X_RES_IMAGE_MODEL |
Image model IP channel |
Apparent chargeability from image model channel for export. Select one from the list, or leave blank and none will be exported. Script Parameter: IP.I2X_IP_IMAGE_MODEL |
Synthetic resistivity channel |
Synthetic resistivity data from image model channel for export. Select one from the list, or leave blank and none will be exported. Script Parameter: IP.I2X_RES_IMAGE_SYNTH |
Synthetic IP channel |
Synthetic chargeability from image model channel for export. Select one from the list, or leave blank and none will be exported. Script Parameter: IP.I2X_IP_IMAGE_SYNTH |
Resistivity (Polygon) channel |
Apparent resistivity synthesized from the polygon model channel for export. Select one from the list, or leave blank and none will be exported. Script Parameter: IP.I2X_RES_POLY |
IP (Polygon) channel |
Apparent chargeability synthesized from the polygon model channel for export. Select one from the list, or leave blank and none will be exported. Script Parameter: IP.I2X_IP_POLY |
Export: |
IP Data Channel for export. Select one from the list, or leave blank and none will be exported. Script Parameter: IP.I2X_LINES - "A" : All lines, "S" : Selected lines (default), "D" : Displayed line |
The IPEXPRESIX GX is used to export one or more lines from the current database to individual Interpex I2X format files. The file names are created from the line numbers and the extension ".i2x". One file is created for each line. Care should be taken as previously created files in the working directory with the same names will be overwritten.
- Import an Interpex I2X Format File (PIMPRESIX GX)
- The Interpex RESIX IP2DI program manuals
