Export to Scintrex Geophysical Data Format File
Use the IP & Resistivity > Export > Scintrex Geophysical Data Format option (IPEXPSGDF GX) to export lines from the current database to a Scintrex Geophysical Data Format (SGDF) file.
Export to Scintrex Geophysical Data Format File dialog options
SGDF file |
Name of the file to create Script Parameter: IP.SGDFFILE |
Export |
Select which lines to export. The options are the currently displayed line, the selected lines (the default) and all the lines. Script Parameter: IP.LINES - "A" : All lines, "S" : Selected lines (default), "D" : Displayed line |
IP/Amplitude Channel |
For time domain, the channel containing the IP data to export. For frequency domain, the amplitude channel. Script Parameter: IP.IPCHAN |
Phase Channel |
For frequency domain, the phase channel. If left blank, the phase is not included in the output. For time domain, this should be left blank. Script Parameter: IP.IPCHAN2 |
