Sample Topography from Grid
Use the IPTOPOGRID GX to import from a grid file the topography information for all the electrodes in the current database.
Import Topography from a Grid file dialog options
Topography grid file |
The file to extract the topography (Z component) from. Script Parameter: IP.TOPOGRID |
The input grid is linearly interpolated to obtain the grid value at each set of XY coordinates in the database. If the XY point falls outside the grid, the returned value is a dummy.
In order to maintain the syntax of the electrode location channel names, if the Z channel(s) are previously present in the database they are silently overwritten.
