Tensioned Spline
Use the Tensioned Spline menu option (LVTSPLN GX) to create a smooth (B-splined) level correction channel.
Tensioned Spline (B-Spline) dialog options
This GX will implement a least-squares smooth fitting of scattered, noisy data using cubic B-splines.
The Roughness controls how well the spline will match the observed data within the standard deviation. A small roughness is smoother than a large roughness. A very large roughness will cause the spline to match the data.
The Tension (Tau) controls the horizontal tension applied to the spline surface. No tension results in a minimum of curvature while a tension of 1 results in piece-wise linear interpolation between points.
