Paste into Map
Use the Paste into Map dialog to paste a copied georeferenced group into a new map view on a map.
Paste into Map Dialog Options
Centred in the display window |
Select the Centred in the display window radio button to paste the group into a new view in the centre of the displayed window. |
Select the Same scale at offset: radio button to enable/disable the X and Y Offset boxes. |
X Offset (mm) |
Specify the X Offset in map units (millimetres). |
Y Offset (mm) |
Specify the Y Offset in map units (millimetres). |
