Geosurface Properties
Use the Geosurface Properties option (geogxnet.dll(Geosoft.GX.Surface.SurfaceProperties;Run)*) to report and modify information about a geosurface file, including information about the file and its contained surfaces, as well as statistical, geospatial and coordinate system information. The Geosurface Properties dialog presents information in different ways, depending on where it was launched from.
You can access the Geosurface Properties dialog from:
  • The Oasis montaj Geosurface > Properties menu
  • The Oasis montaj 3D View >  Geosurface > Geosurface Properties menu
  • The Geosurface Viewer Settings > Properties menu
  • The 3D Viewer Geosurface > Geosurface Properties menu
  • The 3D Viewer and Geosurface Viewer Attributes tab while a Geosurface file is currently selected. Note that two different versions of the dialog will appear depending on whether you have selected the Parent (File level) or the Child (Isosurface level).
Geosurface name
Displays the file name and path of the selected geosurface file.
Extents
Displays the minimum and maximum extents in X, Y and Z for all the surfaces in the geosurface file.
Coordinate system
This displays the coordinate system information of the geosurface, if any. Use the Modify button to modify the coordinate system information.
Coordinate system units
This displays the length units of the coordinate system. The geosurface origin and point separations are in these units. Use the Modify button to modify the coordinate system projection and units.
Number of surfaces
The total number of surfaces contained within the geosurface file.
Surface Properties
Name
The name of the selected surface within the geosurface file. All the properties shown below are related to this surface only.
Source file
Depending on how the surface was created, this could be the voxel file from which the isosurfaces were extracted, the Geosoft string file that the surfaces were wireframed from, or any of the supported formats that can be imported to create a geosurface file, such as Autocad DXF, GoCAD Tsurf files, Vulcan Triangulation files, Leapfrog LFM files.
Surface value
If the geosurface file contains isosurfaces, this will report the surface value that was used during creation.
Feature name
If the geosurface file contains wireframes, this will report the String feature that was used during creation.
Extents
Displays the minimum and maximum extents in X, Y and Z for the selected surface only.
Type
Reports whether the selected surface is Open or Closed. Closed surfaces can be created as isosurfaces or wireframes, or can be imported from 3rd party formats.
Area
Total surface area of the selected surface.
Volume
Total contained volume of the selected surface, if it is closed. Not applicable if the surface is open.
Vertices
Total number of vertices in the mesh of the selected surface.
Triangles
Total number of triangles in the mesh of the selected surface.
  • Use the Validate Surface button to perform advanced validation calculations, and to check for any errors in the selected surface.
  • Surface Validation Properties
    Geosurface name
    Displays the file name and path of the selected geosurface file. The default name is the same as the voxel file name.
    Surface name
    Calculated Validation Properties
    Components
    Total number of separate, individual components within the selected surface. Components are defined as a set of triangles connected by common edges.
    Valid triangles
    Total number of triangles in the surface minus any detected invalid triangles as described below.
    Valid edges
    Total number of valid edges within the selected surface. Valid edges are the total number of unique edges formed by valid triangles (i.e. common edges will be counted only once).
    Inconsistent triangles
    Total number of inconsistent triangles within the selected surface. Inconsistent triangles do not share the same winding as the others in the surface. The winding determines the direction of the normal vectors for triangles and determines the exterior, or positive side, of the surface.
    Invalid triangles
    Total number of invalid triangles within the selected surface. Invalid triangles can be caused by invalid or duplicated vertex locations.
    Self-intersections
    Total number of self-intersections within the selected surface. A self-intersection is where any two triangles intersect by sharing a common region or cutting into each other.
    • When opened from the application menus, the Geosurface Properties dialog has the ability to select any of the contained surfaces in the selected file.
    • When opened from the 3D Viewer or Geosurface Viewer menus, or from the Attributes tab, the properties of the selected surface in the Properties layer tree are available.
    • The Surface Validation Properties dialog, opened when you click the [Validate Surface] button, can be useful to determine if the surface mesh is free of errors or if any errors are present. Errors can lead to incorrect rendering, unexpected behavior, or further errors when the surface is used in Voxel Math.
