Special Tab
Use the Special tab to select some of the more specialized functions used in math expressions.
Special Tab options
Button |
Syntax |
Definition |
Math Functions |
min(,) | The minimum value of 2 channels along each row. |
max(,) |
The maximum value of 2 channels along each row. |
div(,) |
Integer ratio of 2 channels along each row. If floating division is preferred, you can use the / operation, which can be accessed from the Common Keys. The output of division by zero is DUMMY. If either of the 2 channels are DUMMY, the output is set to DUMMY. |
sign(,) |
Transfer the sign of the leftmost argument to the rightmost argument. SIGN(-1,10) = -10 SIGN(-1,-10) = -10 SIGN(1,10) = 10 SIGN(1,-10) = 10 |
ceil() |
Next highest whole value of the specified channel. |
floor() |
Next lowest whole value of the specified channel. |
abs() |
Absolute value of the specified channel. |
round() |
Round up or down the value of the specified channel to a whole value. |
Data |
window(,,) |
The leftmost argument is a channel, while arguments 2 & 3 define the minimum and maximum of a range, outside of which the channel values are set to DUMMY. |
clip(,,) |
The leftmost argument is a channel, while arguments 2 & 3 define the minimum and maximum of a range, outside of which the channel values are set to the limiting value. |
Miscellaneous |
randbetween (,) |
Generate random numbers, between user specified minimum and maximum. To create a new channel and populate it with random values, you must indicate the channel from which to acquire the fiducial start & increment; this is done by specifying the base channel at the end of the equation after the semicolon, i.e., C0=ranbetween(1,100);C1 |
For all the above functions, if the output channel does not exist and the expression does not contain a channel from which to acquire attributes such as start fiducial and increment and data type, you will be prompted to enter a master channel from which to extract the attributes for the new channel about to be created.
