Statistics Tab
The Statistics tab offers simple statistical operators.
Statistics Operators
Button
Syntax
Definition
Operate on line |
Selected: default
Current: _cur is appended to the selected operator
All: _all is appended to the selected operator
This selection determines if the requested statistical property is calculated on the Selected lines, Current line or All lines. The properties listed below are calculated on the line(s) selected.
The Operate on line option is only available with the 'Channel Math' tool and is not available for the 'Grid Math' or 'Voxel Math' tools.
.min
Minimum value of the data
.max
Maximum value of the data |
.mean
Mean value of the data
.range
Range of the data
.count
Number of valid items
.stddev
Standard Deviation
.stderr
Standard Error
.variance
Data variance
.countzero
Number of items equal to 0
.countdum
Number of dummies
.sum
Sum of all data values |
.sum2
Sum of all data squares
.geomean
Geometric Mean (mean of positive values) |
.minpos
Minimum positive value
.countpos
Number of positive values
.sum3
Sum of all cubes
.sum4
Sum of all 4th powers
The statistical property can be calculated on the current, selected, all lines regardless of the selected lines in the database. Once calculated, it can be used in an expression applied to the selected lines. For example, if you would like to calculate the mean of the current line and subtract it from all selected lines you would form the equation below:
C1=C0-C0_curr.mean
Alternatively you could calculate the mean of the data of all the lines and apply it to the current selection
C1=C0-C0_all.mean
The Add Variable @ operator is not supported by the new Statistics dot (.) functions.
The elements of an Array (e.g., C1[1]) are now supported by the new Statistics dot (.) functions.
Tooltips that include an argument and short descriptive name are provided for each tab item.
