Surfaces Tab
The Surfaces tab offers surface operations and is only available with the VOXEL math tool.
Statistics Operators
Button |
Syntax |
Definition |
.intersect | Returns true (1) where voxel cells intersects surface or grid, and false (0) otherwise. |
.inside |
Returns true (1) where voxel cell centers are inside a closed surface, and (0) otherwise. |
.side |
Returns 1 where voxel cell centers are 'above' an open surface or grid, 0 if they "intersect" the surface, and -1 if they are 'below' the surface. The outcome is set to DUMMY if the side cannot be determined. For those voxel cells that do not lie inside the volume normal to the finite surface and bound by the edges of the surface, the surface cannot be determined. |
.dist |
Returns the closest distance of voxel cell centers to a surface or grid, along the normal to the surface. |
.insidedist |
Signed closest distance of voxel cell centers to a closed surface. Positive 'inside' and negative 'outside'. |
.sidedist |
Signed closest distance of voxel cell centers to an open surface or grid. Positive 'above' and negative 'below'. |
