X-Axis Options
The All-Panel Options dialog (accessed from the X Axis Options context menu in the database profile window) enables you to select the channel to use as the X-axis and to automatically rescale the X-axis. You can also choose to display vertical grid lines and to specify the grid line interval.
All-Panel Options dialog options
Select the channel to use as X-Axis |
From the database channel list provided, select the channel to use as the X-Axis. |
Auto rescale X-Axis |
Check the box provided to automatically rescale the X-Axis when you change lines. |
Vertical Grid Lines |
Display |
Check the box provided to display vertical grid lines in the profile window. |
Interval |
Specify the vertical grid line interval. |
