Import Array Data - Geosoft XYZ Import Wizard
On the Import XYZ data dialog, select the Template button: the Import .\filename.xyz dialog will be displayed.
Select (highlight) a sub-Array channel in the data display window.
In the Source Data|Array Size box, specify the size of your Array channel (e.g., 256). The associated Array channels will then be grayed out (if you select (highlight) an associated Array channel).
Click the OK button twice and the selected Array channels will be displayed as an Array in the spreadsheet window.
