Create Geosoft Colour Grid from Aggregate
The Create Geosoft Colour Grid from Aggregate option (AGGGRID GX) will create a colour grid from an aggregate on a map.
Create Geosoft Colour Grid from Aggregate dialog options
Map aggregate
Select a map aggregate from the list of aggregates on the currently displayed map.
Script Parameter: AGGGRID.IN
Reference grid file
Select a reference grid on which to base the output colour grid. The reference grid is used to establish the coordinate system and image pixel resolution for the output colour grid. The aggregate will be sampled to match the reference grid.
Script Parameter: AGGGRID.REF
Output grid file
The name of the output colour grid file. This should normally be a Geosoft colour grid.
Script Parameter: AGGGRID.OUT
This GX is normally used to create a colour image file from a data grid for use as the default image on a DAP Web server. See the DAP Administrator documentation for more information about using an image file to support DAP web pages.
