Merge GPS Data to Survey Database
Use the Moving Platform Gravity > Import > Merge GPS Data to Survey Database menu option (AGMERGE GX) to merge GPS data into the gravity database.
Merge GPS Data into Gravity Database dialog options
Gravity database
Name of the gravity database.
Script Parameter AGMERGE.GRAV
GPS database
Name of the GPS database.
Script Parameter AGMERGE.GPS
Merge GPS data (Latitude, Longitude and Height channels) into gravity database by matching the Date and Time values from the Date and Time channels.
The GX first creates the "_lookup.tbl" file from the GPS database with Date, Time, Latitude, Longitude and Height fields in the table. Then merges Latitude, Longitude and Height data into the gravity database by using Tablelook2_DU method with Date and Time indexes.
