Normalize Assay Channels
Use the Geochem Analysis > GeochemUtilities > Normalize Assay Channels option (CHNORM GX) to normalize one or more ASSAY class channels.
Normalize ASSAY channels dialog options
The CHNORM GX creates a new, normalized channel by adding "_N" to the selected channels. It normalizes the data using the following steps (R = defined output range):
Determine the maximum value in the data ("Max")
Get the outlier limit ("Out")
If no outlier limit is defined, or if the maximum data value is less than the outlier limit, then multiply all the data by R./Max.
If an outlier is defined, and it is less than the maximum data value, multiply all the data by R/Out.
