Profile Plot
Use the Geochem Map > Line Plots > Profile menu option (CHPROF GX) to draw profiles of channel values for all selected lines in a database.
Profile Plot dialog options
Profile channel
Profile channel to select
Script Parameter: PROFILE.CHANNEL
Line colour
line colour
Script Parameter: PROFILE.COLOR
Line thickness (mm)
line thickness
Script Parameter: PROFILE.THICKNESS
Line style
line style number
Script Parameter: PROFILE.STYLE
Line pitch (mm)
line pitch
Script Parameter: PROFILE.PITCH
Profile scale (units/mm)
vertical scale in units/mm
Script Parameter: PROFILE.SCALE
Profile base
profile base level, blank for line minimum
Script Parameter: PROFILE.BASE
Maximum down-line gap
maximum down-line gap
Script Parameter: PROFILE.GAP
Join to line ends?
1 - join line ends 0 - do not join line ends
Script Parameter: PROFILE.JOIN
This GX is for use with geochemical data acquired along survey lines.
