Plot Triplot Graph
Use the CHPRTRI GX to print a TriPlot.
Plot Triplot Graph dialog options
Title
Type the title for the TriPlot
Triangle side length ( mm)
Length of each side of the TriPlot triangle in (mm)
Symbol Size (mm)
The size of the plotted symbols in mm.
Plot to
Select one of "new map" or "current map".
Locate Plot (plot to current map only)
Bottom left X (mm)
X Location for bottom corner of the plot.
Bottom left Y (mm)
Y Location for bottom corner of the plot.
Locate
Interactively select the location of the bottom left corner by selecting a point on the current map
Click on the Print button image\ebx_141323220.jpg in the Triplot Analysis tool.
Enter a title, the width and the symbol size for the plot.
New map names are created in the following format: Triplot_RightChannel_LeftChannel_TopChannel.map, or, if a template is specified using the GX parameters, the template name is used. If a map of that name already exists, it is overwritten.
