Create Subset Database
Use the Database Tools > Geostatistics Toolkit > Create Subset Database or the Geochem Analysis > Create Subset Database menu options, (CHSUBSET GX), to create a new SUBSET database from a Master database. The subset database will only include data that is not dummy in the Mask channel.
New subset database
The new subset database you wish to create
Script Parameter: CHSUBSET:DATABASE
Mask channel
The channel you wish to use as the mask channel.
The default mask channel is set from the CHPREFERENCES GX (Geochem Import/Preferences...).
Script Parameter: CHSUBSET:CHANNEL
Used to generate a subset database, based on information contained within the mask channel (ChemMask)
