Copy Channel
Use the Database Tools > Channel Tools > Copy Channel menu option (COPY GX) to copy one channel to another.
Copy Channel dialog options
Copy from
Original channel.
Script Parameter: COPY.FROM
Copy to
Destination channel.
Script Parameter: COPY.TO
Decimation factor
Decimation factor, default 1.
Script Parameter: COPY.DECIMATE
New fiducial start
New start fiducial, defaults to FROM fiducial start.
Script Parameter: COPY.FIDSTART
New fiducial increment
New fiducial increment, defaults to FROM fid increment.
Script Parameter: COPY.FIDINCR
If a new channel does not exist, it will be created with the same definition as the original channel. Where the mask channel value is a dummy "*", the copied value will be set to a dummy; otherwise the data is copied as is, subject to the usual rule on data conversion if the original and destination channels are different types.
