Delete Line
Use the Project > Scripting > Delete Line menu option (DELLINE GX) to delete a line or a set of lines from a database.
Delete Line dialog options
Line number or range
Lines to delete
Script Parameter: DELLINE.LINE
This GX will delete lines even if they contain channels that are marked as PROTECTED.
Lines may be selected by name or by range. For example:
L100.2
delete line 100 version 2
L80
delete line 80, all versions
B80
delete base line 80, all versions
T80
delete tie line 80, all versions
R80
delete trend line 80, all versions
S80
delete test line 80, all versions
P80
delete special line 80, all versions
D80
delete random line 80, all versions
80
delete line 80, all versions, all types
L100:300.3
delete lines 100 through and including line 300.3
