Digitize Targets
Use the Digitize Targets dialog (DIGITPROFOP GX/DIGITPROFOPT GX) to view or alter the current settings for the target list, output channels and symbols.
The dialog is activated from the database profile window when clicking on a position in a channel profile and selecting the Target Selection Options or Select Target context-menu items.
Digitize Targets dialog options
Target list
The name of the "group" line to save data.
Script Parameter: DIGITPROF.TARGETS
Channel to save value
Channel to save value. The value from this channel is copied to a channel of the same name in the targets group line. This channel need not be the same as the one displayed in the profile.
The "current" X and Y channels are not available on the drop-down channel lists because they are output automatically.
Script Parameter: DIGITPROF.CHAN
Channel #2 (optional)
Channel #3 (optional)
Channel #4 (optional)
Select up to three additional channels whose values will be saved to the target list.
Script Parameter: DIGITPROF.CHAN2, CHAN3, CHAN4
Plot symbol on current map?
If "yes", the selected target is plotted on the current map at the corresponding X, Y location. By default, no symbol is plotted.
Script Parameter: DIGITPROF.PLOTSYMB (0:No, 1: Yes)
[Symbol]
Select the Symbol button to define (or re-define) the symbol for plotting.
