Export to Esri File Geodatabase
Use the Database > Export > Esri File Geodatabase menu option (geogxnet.dll(Geosoft.GX.Database.ExportToGeodatabase;Run) *) to export survey data from a Geosoft database to an Esri File Geodatabase, as point features or line features.
Export to Esri File Geodatabase dialog options
- Because the Geosoft database and the Esri File Geodatabase both use *.gdb as a file extension, you cannot create an output File Geodatabase with the same name as the current database in the same folder.
- The X, Y coordinates must be set in the Geosoft database to export it to a File Geodatabase.
- The coordinate system of the Geosoft database is written to the output feature class.
- If the Z coordinate is set in the Geosoft database, points or lines with Z coordinates are saved to the feature class.
- Any X, Y or Z coordinates that are dummy (*) will not be exported to the feature class.
- Data channels that contain dummies will be exported as <Null> to the feature class.
