Select/Deselect Version
Use the Select/Deselect Version menu option (geogxnet.dll(Geosoft.GX.Database.SelectLinesByVersion;Run)*) to select or deselect lines versions.
Select/Deselect Version dialog options
Version |
Select version number. This is the number after the decimal in the line name. The list is populated with the version numbers present in the database. Script Parameter: SELECT_LINES_BY_VERSION.VERSION |
Selection |
Select if lines with the above version are to be appended or overwritten. Overwrite current selection: Only the lines with the above version number will be selected/ deselected, regardless of the previous selection pattern. Append current selection: Apply the selection ONLY to the lines with the above version, and for all other lines with a different version number, the existing selection remains. Script Parameter: SELECT_LINES_BY_VERSION.METHOD[0 – Overwrite (default), 1 – Append] |
[Select] |
Click to select the line. Script Parameter: SELECT_LINES_BY_VERSION.OPTION[0] |
[Deselect] |
Click to deselect the line. Script Parameter: SELECT_LINES_BY_VERSION.OPTION[1] |
