Located An-Eul Solutions
Use the Euler 3D > Located An-Eul Solutions menu option (E3ANEULER GX) to apply the An-Eul method to determine the source depths and structural indexes of a list of anomaly locations in the current database.
Located An-Eul Solutions dialog options
X derivative grid (.grd)
Input X-Derivative Grid file name.
Script Parameter: EULER3D.DX
Y derivative grid (.grd)
Input Y-Derivative Grid file name.
Script Parameter: EULER3D.DY
Z derivative grid (.grd)
Input Z-Derivative Grid file name.
Script Parameter: EULER3D.DZ
Line containing grid peak locations
The "group" line in the database in which the grid peak locations had been saved.
Script Parameter: EULER3D.XYSOLGRP
Line for An-Eul solutions
The "group" line in the database to which the solutions (depths and indexes) are to be written. If the selected group already exists, it will be overwritten. If it left blank (the default), the solutions are to be written to the existent grid peak locations line.
Script Parameter: EULER3D.SOLGRP
Flying height
Flying height of observation plane (default=0.0)
For drape airborne surveys, enter the flying height. Depths will be reported as depth below ground by subtracting the flying height. By default, depth below plane of observation is reported.
Script Parameter: EULER3D.OBSHGHT
Survey elevation
Elevation of observation plane
For barometric airborne surveys, enter the survey elevation. Depths will be reported as elevations by subtracting the model depth from the survey elevation.
  • By default the flying height will be used, unless a survey elevation is entered.
  • Script Parameter: EULER3D.OBSELEV
    Located An-Euler Method
    The An-Eul method (E3ANEULER GX) determines the depth and structural index of a list of anomalies. The anomaly list is generally produced using an automatic peak-finding routine which locates peaks (E3PEAKS GX). The depth and index are then calculated at these locations using the An-Eul method.
    Theory
    Based on substituting derivatives of Euler’s equation into the analytic signal equation, An-Euler method is able to estimate simultaneously the source parameters, depth and index:
    Depth = (AS1*AS0) / (AS2*AS0 - AS1*AS1) at the peak location x=x0, y=y0
    Index = (2*AS1*AS1 – AS2*AS0) / (AS2*AS0 - AS1*AS1) at the peak location x=x0, y=y0
    Where
    AS0(x,y) = sqrt ( (dT/dx)^2 + (dT/dy)^2 + (dT/dz)^2 )
    AS1(x,y) = sqrt ( (dT/dxdz)^2 + (dT/dydz)^2 + (dT/dzdz)^2 )
    AS2(x,y) = sqrt ( (dT/dxdzdz)^2 + (dT/dydzdz)^2 + (dT/dzdzdz)^2 )
    Input and Output Channels
    Input Channels
    (Created using the E3PEAKS GX)
    X
    = x coordinate of the center of the search window.
    Y
    = y coordinate of the center of the search window
    Output Channels
    Depth (or Elevation)
    = solution depth (z coordinate). If a survey elevation is entered, the channel name becomes "Elevation"
    Index
    = solution index (structure index)
    Mask
    = a flag indicating whether this solution is to be plotted or not (1 for plot, * for don't plot). Initially all Mask values are 1. The E3WINDOW GX edits the Mask channel to select only significant solutions for plotting.
    Structural Index (SI)
    A structural index is an exponential factor corresponding to the rate at which the field falls off with distance, for a source of a given geometry.
    The following table provides an appropriate model for the structural index value.
    SI
    Magnetic Field
    Gravity Field
    Contact / Step
    Sill / Dyke / Ribbon / Step
    1
    Sill / Dyke
    Cylinder / Pipe
    2
    Cylinder / Pipe
    Sphere
    3
    Sphere / Barrel / Ordnance
    N /A
    Another way to determine an appropriate structural index is to determine how many infinite, or reasonably large dimensions are present in a given model. The model SI is this number subtracted from the maximum SI for a given field, which is 3 for magnetic data and 2 for gravity data.
    Note that a zero index implies that the field (magnetic or gravity) is constant regardless of distance from the source model. These solutions are physically impossible for real data, and a zero index represents a physical limit which can only be approached as the so-called ‘infinite’ dimensions of the real source increases. In practice, an index of 0.5 can often be used to obtain reasonable results when an index of zero would otherwise be indicated.
    Geological Model
    Number of Infinite dimensions
    Magnetic SI
    Gravity SI
    Sphere
    3
    2
    Pipe
    1 (Z)
    2
    1
    Horizontal cylinder
    1 (X or Y)
    2
    1
    Dyke
    2 (Z and X or Y)
    1
    Sill
    2 (X and Y)
    1
    Contact
    3 (X, Y and Z)
    NA
    References
    • [1] Salem and Ravat, 2003, , "A combined analytic signal and Euler method (AN-EUL) for automatic interpretation of magnetic data", GEOPHYSICS,, vol. 68, no. 6 (Nov - Dec 2003), pp. 1952-1961
