Select All
Use the Euler 3D > Select All menu option (E3WINDRS GX) to select all solutions from a selected Euler deconvolution solution set, using the mask channel.
Select All Euler Decon Results dialog options
Solution list
The Name of the "group" line with solutions. This value is the same as the most recently specified solution list from any of the other GXs that require a Solution List.
Script Parameter: EULER3D.SOLUTIONS
Mask channel
The mask channel is updated by the windowing operation. The mask channel is used for selecting a subset of solutions from the solution list. This channel is initially set 1 to indicate that all solutions are selected. If the value is set to 0 or dummy (*), then this solution will be ignored in operations making use of the mask channel.
Script Parameter: EULER3D.MASK
Applications Notes
This GX is useful in the case of restarting to window the data after using E3WINDOW to select solutions.
