Export Map to BMP or PLT
The EXPMAP GX exports a map to a bitmap or external plot file.
This GX runs from a script. The Export function in Oasis montaj can be recorded.
Script Parameters
File
File name to create.
Script Parameter: EXPMAP.FILE
Mode
Map export options:
0 – Export in View Mode
1 – Export in Raster Mode
Script Parameter: EXPMAP.MODE
All
Export Entire Map or a region:
0 – Specified Region
1 – Entire Map
Script Parameter: EXPMAP.ALL
MinX
MinY
MaxX
MaxY
Specify view area. Only needed if not exporting entire map. In View mode the values are in view units, and in Raster mode the values are in millimeters.
Script Parameter: EXPMAP.MINX
Script Parameter: EXPMAP.MINY
Script Parameter: EXPMAP.MAXX
Script Parameter: EXPMAP.MAXY
Bits
Output colour depth information. Must be one of:
0 - Default Colour
1 - Black & White (dithered)
4 - 16 Colour (dithered)
5 - 16 Shades of grey (dithered)
8 - 256 Colour (dithered)
9 - 256 Shades of grey (dithered)
24 - True Colour
Script Parameter: EXPMAP.BITS
Dither
Controls the dithering for colour bits 1,4,5,8,9:
0 - Standard Regular Dither
1 - Error Diffusion Dither
Script Parameter: EXPMAP.DITHER
Dots per inch
If output format is a raster type this will override RES or SIZEX and SIZEY below. Map page size will be used to determine pixel size of output.
Script Parameter: EXPMAP.DPI
View Mode Script Parameters
View
Name of the View to export coordinates in.
Script Parameter: EXPMAP.VIEW
Resolution
Resolution of a pixel in view units. This parameter is used to size any raster images exported.
Script Parameter: EXPMAP.RES
Export Format
Type of output file to create:
  • PLT Geosoft Plot (*.plt)
  • SHP ArcView Shapfile (*.shp)
  • DXF12 AutoCad12 (*.dxf)
  • DXF13 AutoCad13 (*.dxf)
  • GTIFF GeoTIFF (*.tif),
  • MTIFF MapInfo TIFF (*.tif)
  • ATIFF ArcView TIFF (*.tif)
  • GEO Geosoft COLOR grid (*.grd)
  • ERM ER Mapper RGB (*.ers)
  • Google Earth Keyhole Markup (*.kmz)
Script Parameter: EXPMAP.FORMAT
Raster Mode Script Parameters
SizeX
Number of pixels in the X direction to export. This and the SiseY parameter together define the output size. However, the user should only specify one of these options and place 0 for the unspecified one. The software will automatically compute the unspecified parameter to keep the aspect ratio of the exported map.
Script Parameter: EXPMAP.SIZEX
SizeY
Number of pixels in the Y direction. See SizeX for comments.
Export Format
The following output formats are supported in Raster mode:
  • EMF Enhanced Metafile (*.emf)
  • BMP Bitmap (*.bmp)
  • JPEGL JPEG Low Quality (*.jpg)
  • JPEGH JPEG High Quality (*.jpg)
  • GIF GIF (*.gif)
  • PCX PCX (*.pcx)
  • EPS Encapsulated PostScript (*.eps)
  • TIFF TIFF (*.tif)
