Vertical Derivative Filter
Use the Vertical Derivative option to apply a Fast-Fourier Transform Vertical Derivative filter to a channel.
  • Geophysics: 1D FFT > 1D Filtering
  • Gravity and Terrain Correction: Moving Platform Gravity  > Apply Single FFT Filter
Vertical Derivative filter options
Order of Derivative
Order of derivative.(default = 1)
Script Parameter: FFTVDRV.ORDER
The vertical derivative is commonly applied to total magnetic field data to enhance the most shallow geological sources in the data. As with other filters that enhance the high wavenumber components of the spectrum, it is often necessary to apply an additional low-pass filter to remove high wavenumber noise.
n Order of differentiation.
