Save Section Grid(s) to Database
Use the Section Tools > Save Section Grid(s) to Database menu option (geogxnet.dll(Geosoft.GX.Database.SectionGridsToDatabase;Run)*), to import gridded section data into a new or existing database.
Save Section Grid(s) to Database dialog options
Input grid file(s)
Select the input section grid data file(s) to import into a GDB. Each line will be named after the section grid name.
Script Parameter: GRID2ARRAYGDB.GRD
Output database
Select the output database file name in which to save the section data. If the database already exists, new lines will be added to it.
Script Parameter: GRID2ARRAYGDB.GDB
Output array channel
Specify the database array channel, in which to store the section grid(s) in array format. The depth information will be embedded into the array channel header.
Script Parameter: GRID2ARRAYGDB.CHAN
Output elevation channel
Specify the data channel to populate with the elevation. The elevation is compiled as the topmost non-dummy section cell Z position.
Script Parameter: GRID2ARRAYGDB.ELEV
Save trace only
The georeferenced X & Y positions of the top of the section trace are saved as channels. By checking this box, the array data will not be saved.
Script Parameter: GRID2ARRAYGDB.SAVE_TRACE [1- YES ( DEFAULT), 0- No]
This GX accepts gridded section file(s) as input and saves them into a database as an array channel. The geo-referenced X & Y, and optionally the elevation, are saved as data channels in the same database. The elevation channel contains the first non-dummy value found in each grid.
