Grid Histogram
Use the Grid Histogram option (GRIDHIST GX) from the Grid and Image > Display on Map menu or the Map Tools > Symbols menu to plot a grid histogram.
The option is also available with the Grav/Mag Interpretation extension under the menu Euler 3D > Plot Solution Symbols.
Grid Histogram dialog options
AGG/layer group
view/agg/layer name for the primary colour bar ITR.
Script Parameter: GRIDHIST.AGG
Title
Histogram Title.
Script Parameter: GRIDHIST.TITLE
Annotation size (mm)
Annotation size. Annotations that are too crowded will be dropped from the annotation axis of the colour bar.
Script Parameter: GRIDHIST.ANNSIZE
Number of bins
The number of histogram bins. Select a value from 2 to 1000.
Script Parameter: GRIDHIST.BINS (default 50)
Histogram height (mm)
The histogram height.
Script Parameter: GRIDHIST.HEIGHT
Histogram width (mm)
The histogram width.
Script Parameter: GRIDHIST.WIDTH
Map location X (mm)
The X location of the bottom left corner of the histogram on the current map. Click on the Locate button to locate the histogram interactively.
Script Parameter: GRIDHIST.X
Y (mm)
The Y location of the bottom left corner of the histogram on the current map. Click on the Locate button to locate the histogram interactively.
Script Parameter: GRIDHIST.Y
Data distribution
By default, the histogram X scale is linear. If a logarithmic distribution is chosen, then the X scale is logarithmic, and the bin sizes increase as the log of the data value.
Script Parameter: GRIDHIST.LOG (0:Linear (default), 1:Logarithmic)
Summary statistics
Print summary of statistics? "Yes" or "No" (default No).
Script Parameter: GRIDHIST.SUMM
Box-Whisker plot
Draw a Box-Whisker plot? "Yes" or "No" (default No)
Script Parameter: GRIDHIST.BOXWHISKER
Probability scaling for %
Re-scales the accumulated probability curve assuming a normal distribution of data (as if the data were plotted in terms of standard deviations from the mean). "Yes" or "No" (default No).
Script Parameter: GRIDHIST.PROBABILITY
