Grid Point Value
Use the Grid and Image > Utilities > Point Values menu option (GRIDVALUE GX) to calculate and report the grid value at a selected location from up to four grid files.
Point Values dialog options
Grid 1
Grid 2
Grid 3
Grid 4
The names of up to four grids to report.
Script Parameter: GRIDVALUE.GRD1
Script Parameter: GRIDVALUE.GRD2
Script Parameter: GRIDVALUE.GRD3
Script Parameter: GRIDVALUE.GRD4
[Point]
After pressing this button you will be able to select a point on the current map. The values of each of the specified grids will be reported in a separate dialog.
Grid Values at a Point dialog options
Map X
Map Y
This is the X, Y location that has been selected. You can change these values directly in the dialog to determine the grid values at a specific location.
Grid name
The name of each grid specified appears with the grid value at the selected point.
[Point]
After pressing this button you will be able to select a new point on the current map. The values of each of the specified grids will be reported. You can also just press return, then click on a new location.
[Calc]
If you have changed the X, Y values directly, this button will calculate the grid values at the new location.
After pressing the Point button, you will be able to select a point on the current map. The values of each of the specified grids will be reported in a separate dialog.
