Grid Volume
Use the Grid and Image > Utilities > Grid Volume menu option (GRIDVOL GX) to calculate the volume of space defined by a grid surface, above and below a base of reference.
Grid Volume dialog options
Volume Report dialog options
| Volume above reference base | Volume of grid above REFBASE (Output!) Script Parameter: GRIDVOL.ABOVE |
| Volume below reference base | Volume of grid below REFBASE (Output!) Script Parameter: GRIDVOL.BELOW |
| Difference | Difference between volumes (Output!) Script Parameter: GRIDVOL.DIFF |
GRIDVOL.ABOVE, GRIDVOL.BELOW, and GRIDVOL.DIFF are output values only. GRIDVOL.ABOVE and GRIDVOL.BELOW are reported as positive values.
GRIDVOL can be useful for determining the volume of material defined by grid surfaces in topographic applications. Some geophysical applications also make use of volumes under anomalies to derive physical properties (e.g. gravity).
The volume of the grid is simply displayed on the default output as a floating point number. This output can be piped to another application if desired. The volume is calculated by summing the product of the grid cell area times each non-dummy grid point.
