GOCAD to Voxel
Use the Voxel > Conversions > GOCAD to Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ImportGocadToVox;Run)*), to import GOCAD Voxet files to a Geosoft Voxel.
The import only supports GOCAD files in IEEE float format with property data in an external file.
GOCAD to Voxel dialog options
GOCAD Voxet file
Browse to select the GOCAD Voxet file to import.
Script Parameter: IMPORTGOCADTOVOX.GOCAD_VOXET_FILE
Output voxel
Specify the name of the Geosoft Voxel file to generate (.geosoft_voxel).
Script Parameter: IMPORTGOCADTOVOX.OUTPUT_FILE
Property to import
Select a property in the GOCAD Voxet file to import.
Script Parameter: IMPORTGOCADTOVOX.PROPERTY
Orientation
Select the orientation of the Z axis of the GOCAD file.
Script Parameter: IMPORTGOCADTOVOX.ORIENTATION
  • "Standard" is +Z up and "Inverted"  is +Z down. See Application Notes for GOCAD and Oasis montaj conventions and standards..
  • Coordinate System
    Coordinate System
    The Coordinate System dialog allows you to specify the correct coordinate system information (Datum and Projection Method) for the incoming GOCAD Voxet file.
    Script Parameters:
    • IMPORTGOCADTOVOX.IPJ_NAME
    • IMPORTGOCADTOVOX.IPJ_DATUM
    • IMPORTGOCADTOVOX.IPJ_METHOD
    • IMPORTGOCADTOVOX.IPJ_UNITS
    • IMPORTGOCADTOVOX.IPJ_LOCALDATUM
    In GOCAD, the standard is Z-positive down (depth), whereas in Oasis montaj the convention is Z-positive up (elevation). In the dialog, you may specify either “standard” or “inverted” orientation, where "standard" is Geosoft’s standard, or “inverted” equates to GOCAD standard, as shown in the table below:
    Dialog Option
    Description
    ZPOSITIVE Elevation
    ZPOSITIVE Depth
    ZPOSITIVE Elevation ( Z First)
    ZPOSITIVE Depth (Z First)
    Standard
    Inverted
    Standard (Z first)
    Inverted (Z first)
    If a 3D Viewer is open during the import, then the output voxel will be displayed in that 3D view. Otherwise, the output voxel will be displayed into a new Voxel Viewer window. If the output voxel does not display, open the Advanced Settings dialog (Settings | Global Settings | Advanced) and under the Voxel Settings section, check if the Display Created Voxels option is set to "True".
